1030 oil usage
Dairy Farmer in
06-11-2007 18:29:46
anyone have a 1030 that uses a lot of oil? it don't smoke like it's burning 10 gallons an hour. it just smokes lightly blue like all diesels do. i got a 4020 that smokes more blue but don't uses a drop of oil. just curious what it is and if anyone else's does this too.
DF in WI
Bob/wis
06-12-2007 10:56:45
 Re: 1030 oil usage in reply to Dairy Farmer in WI, 06-11-2007 18:29:46
The worse I have every seen adn still running was our first 1030. It would go through 2 gallon a day under heavy field work. I mean this was a solid 8 hr days. Does yours have oil leaks? The 10's did not have as much head leaks as the 7's and 9's due to their metal gaskets. Loose valve guides and worn rings will cause a excessive use of oil. How much does it go through in a day? I have a 9 and a 7 slated for head gasket replacment in the near future.
Bob
Dairy Farmer in WI
06-12-2007 18:49:46
 Re: 1030 oil usage in reply to Bob/wis, 06-12-2007 10:56:45
it uses anywhere from 2-5 qts a usage if runing it long hours like cutting a lot of hay. ran it for like 3 hrs yesterday and didn't use oil but uses it 3 more hrs today and now the dipstick says "low"
Camboted
06-12-2007 04:05:38
If it starts ok, and youn don't see leaks all over, then you must have broken rings or a head gasket problem, Whatever, I'd say you need to tear it down.
