Case LA Serial Number ?
Richard Still
12-26-1999 13:14:24
I can't seem to find information on a Case LA #5328178LA What year would that be? It is setup for propane but I'm told it has the maniford that can run with either. What would be a fair value for a tractor like this? Thanks
Caseworld
12-27-1999 20:02:27
 Re: Case LA Serial Number ? in reply to Richard Still, 12-26-1999 13:14:24
LP-Gas Equipment for LA Tractors was first offered as an option in 1952. There were conversion kits available to change gas powered LA's to LPG(propane)powered tractors. Since your tractor was manufactured in 1949, it was converted at a later date. There should be a way to convert it back to gasoline. There is information on LA's on Caseworld's website...www.geocities.com/caseworld
Good Luck GK
Jerrie Lott
12-26-1999 15:32:41
Since it is a seven digit searial number you subtract 4 from the first two number which makes it a 49 model. As far as burning either gasoline or propane, I don't know for sure, the manifold could be the same but if you don't have a carb, you would have no way to get the gasoline into the engine, hopefully someone else with more expertise will answer this also.
