tractor worth?
pasbonbasile
06-20-2007 05:41:08
I posted a picture under photos labeled LA CASE? and was wondering what would a fair price for it be? yr unknown and engine stuck.
JHH
06-20-2007 18:58:37
 Here is the pic in reply to pasbonbasile, 06-20-2007 05:41:08
pasbonbasile said: (quoted from post at 05:41:08 06/20/07) I posted a picture under photos labeled LA CASE? and was wondering what would a fair price for it be? yr unknown and engine stuck.
third party image
toomanycases
06-20-2007 12:34:44
 Re: tractor worth? in reply to pasbonbasile, 06-20-2007 05:41:08
Hi, just being noisy, do you have the serial # on it, or do you know what year it is? With full steel wheels looks like it would be fun to restore. Looks like you got a great buy.
pasbonbasile
06-20-2007 13:09:36
 Re: tractor worth? in reply to toomanycases, 06-20-2007 12:34:44
Not yet, i have been searching through the archives for serial tag location, or some other way to ell what year it is and have a general idea where to look. Going back saturday to pick it up, then will be able to go over it with a fine tooth comb to see if I can come up with any numbers. any help will be appreciated, as this is my first non-green tractor, but at that price i couldn't pass it up.
JGarner
06-21-2007 06:06:05
 Re: tractor worth? in reply to pasbonbasile, 06-20-2007 13:09:36
If its like the SC and DC of same vintage the serial number is riveted somewhere on the lower edge of the dash/instrument panel.
pasbonbasile
06-20-2007 10:29:14
well sometimes its best i think to let the others make an offer of what they want. this time it payed off. I just bought the thing for 100.00, couldn't pass it up at that price.
DurangoCase
06-20-2007 07:26:55
$650-750 if it all there.
jal-SD
06-20-2007 07:24:09
Brother in law & I bought a running '49 LA in central SD in the fall of '05. Good sheet metal, one good rear tire, w/all tires holding air. Gave $900 for it on an auction. Put new fronts & a different rear after the one that was on it blew, loosing all fluid. It gets used all the time, it and a 930 put in all the crops last spring when the main tractor (a 5080 AC) had a little rod bolt problem that turned into a "look-in" crank case. Hope this gives you some idea of what it may be worth. (My $0.02 worth. jal-SD)
