1175vs1370 injectors
705
07-16-2007 07:32:11
is there any difference between the 2?
mEl
07-16-2007 17:57:58
 Re: 1175vs1370 injectors in reply to 705, 07-16-2007 07:32:11
Since there is a difference in the bore of the two engines you shoud probably contact a diesel shop with the manufacturers number of the injectors. They MAY spray at a different angle, maybe even have more openings but I doubt that.
Oregon - Jim
07-16-2007 17:36:19
Two different part numbers. 1175 nozzle substitutes to current Case-IH part number A-138322. 1370 Nozzle shows part number A-138323. If you pull the nozzle, you should find a stamped number on the body that your dealer (or a good fuel injection shop) can cross reference to the Case-IH part number.
