188 diesel rebuild
dicksta
07-19-2007 03:17:01
Do connecting rod oil holes go toward camshaft or toward left side of block.
dicksta
07-21-2007 17:26:46
 Re: 188 diesel rebuild in reply to dicksta, 07-19-2007 03:17:01
Thanks for the info folks!! I can move forward now.
dicksta
07-19-2007 05:19:46
I guess I don't understand.
Roger (Mi)
07-19-2007 05:42:47
 connecting rod numbers in reply to dicksta, 07-19-2007 05:19:46
mBl is right! Unless someone has changed things from the factory, all connecting rods have numbers on the rod itself and the rod cap. That's done so that you don't mixup the rods and rod caps. Also, they're numbered so that you can put the piston back into the same bore if you're re-ringing. Those two matching numbers on the rod/rod cap will face the CAMSHAFT when being installed. There should be a small arrow (on most 188 pistons) on the top of the piston. Make sure that arrow points to the front. If you put the pistons in 180 degress wrong, the pistons will hit the valves!
Roger (Mi)
07-19-2007 05:47:25
 Sorry, hit the wrong key in reply to Roger (Mi), 07-19-2007 05:42:47
It's mEl, not mBl.
mEl
07-19-2007 04:34:00
number toward cam.
