What paint color for 70's Case 580 backhoe?
sbin
07-24-2007 20:04:49
Just traded for a 1976 Case 580c backhoe and want to paint parts as we replace various bushings,pins and rebuild cylinders.
Can anyone recommend a quality paint close to the original color?
Going to spend some time sand blasting and priming it so it would be nice to have the top coat look respectable.
Dennis/Ohio
07-30-2007 02:33:39
 Re: What paint color for 70's Case 580 backhoe? in reply to sbin, 07-24-2007 20:04:49
I have the current production color on my old hoe. Power Tan from the Case Dealer. I think it makes the machine look newer. The Case primer & color are holding up well. It doesn"t have a hardner available. Not expensive in gallons.
Best, Dennis..... ..
sbin
08-03-2007 09:37:25
 Re: What paint color for 70's Case 580 backhoe? in reply to Dennis/Ohio, 07-30-2007 02:33:39
Thanks Dennis,
I just got back from buying paint at the local Case dealer.The paint was around $40 a gallon.
What part of Ohio do you live?
We live around Cleveland and once the backhoe leaks are fixed and it is painted it will be on property near Middlefield
Dennis/Ohio
08-03-2007 23:40:18
 Re: What paint color for 70's Case 580 backhoe? in reply to sbin, 08-03-2007 09:37:25
Hello,
I"m in Akron.
Good luck with your project.
Best, Dennis.....
