What is an Eagle Hitch
Jeff McBride
07-27-2007 20:14:07
third party image
I here you guys talking about eagle hitches adn eagle three point ect ect. What kind of hitch is this. It is either up or down and works off pto
Jeff McBride
07-28-2007 20:09:35
 Re: What is an Eagle Hitch in reply to Jeff McBride, 07-27-2007 20:14:07
Thanks to all. That somes it up somewhat.
JGarner
07-28-2007 19:35:02
I think this is going to work this time Jeff.
All, forgive my stupidity and all the posts to get this show and tell up.
This is the eagle hitch on my 630. VAC series tractors look slightly different and were stared in 1949 I think. Appeared on SC and DC in 1952. Eagle hitch looked similar on all tractors until it was dropped on 1964/1965 models. The top link shown is for a class 2 hitch (730/830) I have replaced the bent and shabily reinforced lift links and welded up draft arms as well as fabricated a 630 look alike top link from a VAC version. Anyone need a class 2 top link??
Areo
07-28-2007 15:57:34
Yours is a "mechanical lift", not hydraulic. The "Eagle Hitch" was a take off of Cases "Eagle" emblem. The ends of the lift arms had inverted "eagle claws" instead of swivel balls. What I could never grasp was why the lift arms were rigid up and down only, no side to side motion. Must have been fun plowing a curve. Never used one in the field, only for lift boom work.
Areo
dctom
07-29-2007 15:26:42
 Re: What is an Eagle Hitch in reply to Areo, 07-28-2007 15:57:34
NO PROBLEM, THE SWING WAS BUILT IN TO THE IMPLEMENT BEST 3 POINT EVER BUT LIKE MOST OF CASE THINGS YOU HAD TO BE A LITTLE SMARTER THAN TWO POPPERS TO RUN THEM
Jim B
07-29-2007 08:49:23
The lift arms do not swing because during the time frame of the Case "Eagle Hitch", as well as the AC, JD & IH versions of a 3-point system, Ol' Henry Ford & Harry Ferguson owned the patent rights to the design which has now evolved to the system as we know it yet today. Check it out on this site at:>Link
As>Link to how a plow (or any 3-point implement) could be pulled in a curve without the swinging draft arms... Case plows have a pivot pin built into the hitch to permit turning, to a limited degree.
JGarner
07-28-2007 07:03:26
JGarner
07-28-2007 07:15:30
 Re: What is an Eagle Hitch in reply to JGarner, 07-28-2007 07:03:26
Duh!! Sorry all it helps to attach the photo in the photo section before submitting, I didn't. I think (hope) this will work this time.
JG
JGarner
07-28-2007 07:28:00
 Re: What is an Eagle Hitch in reply to JGarner, 07-28-2007 07:15:30
I feel stupid today!!
JGarner
07-28-2007 07:31:55
 Re: What is an Eagle Hitch in reply to JGarner, 07-28-2007 07:28:00
third party image
Maybe I used the wrong link.
bradley martin
07-28-2007 04:30:01
Your picture shows the mechanical lift that was used on the early SC & DC models to lift the cultivator attachment...it is not eagle hitch. It was used until Case introduced hydraulics to these models(about l950-51). After that, these models(and subsequent models) were equipped w/ Eagle Hitch, similar to 3pt hitch but the lower arms had no lateral movement and attached to the implement w/ hooks similar to a quick hitch attachment.In the early '60s, Case began makeing a regular 3 pt available and Eagle Hitch was eventually discontinued .
Goose
07-27-2007 20:42:59
It was Case's version of a two point hook-up similar to IH and Allis Chalmers in the 1950's and 60's.
Lamont
07-28-2007 05:00:06
 Re: What is an Eagle Hitch in reply to Goose, 07-27-2007 20:42:59
The Eagle Hitch was 3 pt., not 2 pt. The upper, or 3rd, arm would be attached after the lower 2 had been hooked up to the implement.
Jeff McBride
07-27-2007 22:39:11
So what you are saying is the one in the pic is an eagle hitch?
RN
07-28-2007 00:15:58
 Re: What is an Eagle Hitch in reply to Jeff McBride, 07-27-2007 22:39:11
No. sister VA? something has sort of Ford looking type 3 arm unit with lower 2 long arms having a lobster claw coupler- back up to plow or cultivator and get it- the claw- under implement mount pin, then lift to engage. Top link can then be connected. 1 person can connect implement easily instead of 2 people on early Ford 3pt. What is shown in picture looks like some kind of earlier mount useing bolts to attach something like a mower or chopper that would lift. Draw bar hitch maybe for wagon tongues seperate from semi- mounted implement? RN
Camboted
07-29-2007 02:30:54
 Re: What is an Eagle Hitch in reply to RN, 07-28-2007 00:15:58
third party image
Here's a picture
Camboted
07-29-2007 02:36:40
 Re: What is an Eagle Hitch in reply to Camboted, 07-29-2007 02:30:54
third party image
And another:
