2 PTO shafts.
Bill Brox
07-29-2007 03:49:05
Hello,
I have a question.
Does anyone know if someone has made a tractor with 2 PTO shafts in the rear end of a tractor ?
I have heard about several tractors with 1 in the rear, and 1 in the side, but how about 2 in the rear ?
Bill
WK-WA
07-31-2007 21:00:15
 Re: 2 PTO shafts. in reply to Bill Brox, 07-29-2007 03:49:05
Bill: The 254 and 274 and 294 were produced between 1982 & 1986 by Landini for Massey Ferguson. The 254 is 45 HP, the 274 is 55 HP and the 294 is rated at 67. That said, I can only speak for the 274 about the double PTO shafts. The top shaft on mine has hyd pump to power the loader and is controled by a lever on the right side of the dash. The bottom shaft is used for whatever and is controled by a lever on the left side of the rear diff. Drop me a note at waynek@bgwireless and I will take some pictures and sent them to you. Wayne
L.C.Gray
07-31-2007 15:35:30
Many modern IH tractors had both 540 and 1000 rpm shafts. They aren't intended to be used simultaneously.
WK-WA
07-30-2007 20:40:24
MF 274 4x4
Bill Brox
07-31-2007 02:02:05
 Re: 2 PTO shafts. in reply to WK-WA, 07-30-2007 20:40:24
Hm... do you have pictures of the 274 with 2 PTO shafts. I have tried to searvh the net for it, but no luck so far.
Bill
Tom (Ks)
07-29-2007 09:49:25
Some Minneapolis-Molines had them.
JoeBob/IN
07-29-2007 04:39:24
86 series IH
