not pulling
1070 troubled
08-02-2007 10:59:42
need help troubleshooting a clutch or hydrolic problem i backed up and it quit pulling it does not make the reverser come on when step on the pedal and no noises are noted i went through the block on the tranny case nothing found changed the filters all linkages are right oil flow was noted at the c4 c1 ports no guage to test pressure
Thad
08-02-2007 17:45:56
 Re: not pulling in reply to 1070 troubled, 08-02-2007 10:59:42
Start it up and try to put it in one of the 4 speed gears with the clutch out. If it will go into gear with no grinding of gears the trans isnt turning. That means more than likely a torque limiter hub has failed. Hope this helps Thad
1070 troubled
08-02-2007 20:40:21
 Re: not pulling in reply to Thad, 08-02-2007 17:45:56
thanks it will go into gear no clutch no grinding, big problem I guess I'll take it to the shop to have it split the man says 200/300 to split it wander what the cost of parts will be any ideas
