1070 remote valve
Jasonl
08-13-2007 06:53:22
My loader suddenly began to no longer stay up or tilted back as I was lifting bales to load. I do have good pressure and the 3 pt works fine. Any suggestions other than replacing trhe entire remote?
jason l
08-14-2007 08:01:21
 Re: 1070 remote valve in reply to Jasonl, 08-13-2007 06:53:22
DKase,
Does the ball and spring come out immediately when the hose is disconnected or is there a keeper of some kind to access them?
Thanks in advance,
Jason
DKase
08-13-2007 20:56:24
Switch your remotes to make sure the problem is the valve, and not the loader. If it is the valve the check balls, and seats can be serviced to repair the problem.
jasonl
08-14-2007 07:09:39
 Re: 1070 remote valve in reply to DKase, 08-13-2007 20:56:24
Thank you for the suggestion. I switched sides and it took care of the problem. ordered new check balls and springs as one spring seemed to be worn and one was broken. I appreciate your information.
Jason
