1200 tk brakes?
daveminn
08-21-2007 10:53:02
What do you fellow case people think of the 1200 tk hydro vac brake system.How do you start fixing them?Thanks for any advice you guys can give.Dave Ahlgren
robertq
08-21-2007 19:31:18
 Re: 1200 tk brakes? in reply to daveminn, 08-21-2007 10:53:02
they do work,they are some what complicated.I tried to make mine work without using the hydrovac booster,just the master cylinder plumbed to the wheel cylinders.NO good you can't make enough pressure without it. I found a local rebuilder to redo the booster,and the back axle wheel cylinders and master cyl.and really it wasn't very expensive.Will nearly flip you over steering wheel .Get the service book on ebay it really explains the system well.As said it just seems complicated.the wheel hubs are heavy to fool with to get the drums off.my vac pump was good to go ..Hydovac was very common on trucks .and kits are out there.
