1948 DC Case
Doug in IL
08-30-2007 07:37:48
I just bought a '48 DC. I have 2 questions about it. It needs an exhaust manifold elbow. Are those available somewhere? Also, on the brake pedal locking latches (with the teeth cut in them), is there supposed to be a rod or something on them to pull them up into engagement? I see a small hole in each of them that looks like maybe something like that is supposed to go in them. Thanks!
Greenfrog
09-04-2007 21:00:26
 Re: 1948 DC Case in reply to Doug in IL, 08-30-2007 07:37:48
I have a 52. Yes there is a rod under the foot rests that pulls that mechanism into braking position lock. You just kick the pedal to release it. About a 5/16 rod and a small metal loop holds the rear up. I used a conduit two hole clamp!
C. Amick
08-30-2007 18:23:04
John Saeli 315-585-9826 or jsaeli@rochester.rr.com has elbows.
dctom
08-30-2007 09:57:04
POST FOR JOHN SAELI ON THIS BOARD FOR A MAG, I USE A PIECE OF SMALL ROPE FROM ONE BREAK LATCH OVER THE SEAT BRACKET TO THE OTHER BREAK LATCH, VERY EASY TO ENGAGE THEM THAN TOM
