210 bl case clutch trouble.
John G
08-31-2007 13:25:18
Hi.. Could anyone tell me how to adjust the hand clutch on a 1958 case B-L? And how can you tell which clutch is giving you the trouble?
Thank-you,
John
pyjohng@yahoo.com
bradley martin
08-31-2007 16:21:41
 Re: 210 bl case clutch trouble. in reply to John G, 08-31-2007 13:25:18
The hand clutch is adjusted by removing the top cover of the the range transmission. The clutch will be at the front of the box and is adjusted by turning the adjusting ring (there are 2 pins protruding from the back of the ring...1 will be engaged and the other will not. pullthe engaged pin out and turn the ring until the other pin drops in..repeat until the hand clutch requires a 50-60 lb push to snap over center.
