Case D and DC
caseman-d
09-03-2007 13:00:22
Took my Case D and my new DC-3 to a pull in Newell SD this Labor Day weekend. There wasn't a whole lot of Case tractor, 2 SC's, my D and DC, and a Case 500 in my other post. Didn't do to well with the my two but had lots of fun.
Case D in the 5000lb Class
third party image
Case D in 5500lb Class
third party image
Case DC-3 in 6000lb Class
third party image
Turned out I had a pull off against a JD. He went to the left side of track.
third party image
I went to the right, turned out to be the wrong choice.
third party image
Case DC-3 in the 6500lb Class
third party image
Link to additional Pictures of the pull.
caseman-d
http://s80.photobucket.com/albums/j163/tomhuston/Newell%20Pull%202007/
C. Amick
09-04-2007 09:17:11
 Re: Case D and DC in reply to caseman-d, 09-03-2007 13:00:22
Enjoyed looking at the photos. How did the guy with the Case 500 do at the tractor pull?
caseman-d
09-04-2007 19:10:33
 Re: Case D and DC in reply to C. Amick, 09-04-2007 09:17:11
C. Amick said: (quoted from post at 09:17:11 09/04/07) Enjoyed looking at the photos. How did the guy with the Case 500 do at the tractor pull?
Not sure how the 500 did. I watched it pull and it had plenty of power before spinning out. Not sure how many tractors were in that class.
caseman-d
Paul f
09-04-2007 05:44:06
I was curious..don't they smooth the track after each pull??? At our local fair they run a triangular shaped grader up and down to level off any ruts and then pull a compactor (a 12 tired wagon loaded with dirt over the track) They do that after each entrant pulls.
caseman-d
09-04-2007 19:16:06
 Re: Case D and DC in reply to Paul f, 09-04-2007 05:44:06
Paul f said: (quoted from post at 05:44:06 09/04/07) I was curious..don't they smooth the track after each pull??? At our local fair they run a triangular shaped grader up and down to level off any ruts and then pull a compactor (a 12 tired wagon loaded with dirt over the track) They do that after each entrant pulls.
Most times no. I was at a pull a couple of weeks ago and they had a blade and a packer as it was very wet to begin with. They did have a blade the last few times I pulled and kept the holes filled. I was at another club pulling and they reworked the track after each class or more if it got bad.
caseman-d
J. R. McVay, Sr.
09-03-2007 16:50:21
I enjoyed the pictures of your pull. I have two tractors that I pull, a 900 gas and a 930 Diesel that I would like to post pictures of. How do I do it?
caseman-d
09-03-2007 18:57:34
 Re: Case D and DC in reply to J. R. McVay, Sr., 09-03-2007 16:50:21
J. R. McVay, Sr. said: (quoted from post at 16:50:21 09/03/07) I enjoyed the pictures of your pull. I have two tractors that I pull, a 900 gas and a 930 Diesel that I would like to post pictures of. How do I do it?
Once I have the pictures down loaded on the computer I use a photo hosting sight like photobucket.com, once the pictures are uploaded to that sight it is very easy using the ytmag new web sight version. I use two windows so it;s very simple that way. I also pull with a 910B, thats a good puller. I only go to a few pulls a year so I take different ones to see how they do. Here are a couple of my 910 pulling.
caseman-d
third party image
third party image
