Case 400 Value???
MCL
09-15-2007 18:08:39
Forgive me--I'm usually on the Oliver board. My Father-in-law has a 400 Case I think will be for sale. Asked me what it's worth and I don't know. It is a project. It has run fairly recently. I know it hasn't been run for several months-maybe a year or two. It is a gasser, has a wide front (looks factory), eagle hitch, 1 set of hydraulic remotes. I know it is missing a cover over the radiator cap (if there was one). One back rim is shot account leaking fluid. The other one looks weak around the valve stem. Has good 14.9-38 tires. Original paint. No rust bucket but needs repainted.
I converted it to 12 volt about 12 or 13 years ago and it ran good then. Just needs a little work and tlc to be a running tractor. What are these things bringing these days?
C. Amick
09-15-2007 19:00:57
 Re: Case 400 Value??? in reply to MCL, 09-15-2007 18:08:39
This is the the big round nose 400 that was made in 1955 thru 1957, right? Location has a lot to do with price. They are more rare in the east and bring more money. With the wide front, $2,000 to $2,500 around here.
MCL
09-16-2007 05:08:47
 Re: Case 400 Value??? in reply to C. Amick, 09-15-2007 19:00:57
I would say that is the one. It has a rounded grille, tan hood, orange belly, and 4 cylinder gas engine. There were different model 400's? It is located in central IN.
C. Amick
09-16-2007 11:06:35
 Re: Case 400 Value??? in reply to MCL, 09-16-2007 05:08:47
At first there were the round nose 300 and 400 series, then they changed the sheet metal on the 300 series and added a smaller 400, 500, 600, etc. and discontunued the old 400. There was also a 200 and 350 in the mix. The newer sheet metal had the headlights in the front above a screened grill, but used the same tan/orange color scheme.
HAVVEY
09-15-2007 18:27:41
ONE WAS ON EBAY RECENTLY. I WOULD SAY $1-2000
