1370 smoke
AllanC
09-27-2007 21:53:40
My 1370 has taken to smoking when it's working - Black smoke and lots of it. What gives?
casefarmer
09-28-2007 16:27:14
 Re: 1370 smoke in reply to AllanC, 09-27-2007 21:53:40
Check air filter
4435
09-28-2007 20:32:41
 Casefarmer is on thr right track in reply to casefarmer, 09-28-2007 16:27:14
Check air filter inner and outer make sue there are no mouse/bird nests in your intake plumbing before you spend any bucks. Tom
dboll
09-28-2007 05:05:46
good chance the turbo is dragging, if you need shop around, I can buy Air Research factory rebuilds cheaper than generic rebuilds, switch to a 3LM466, for more boost.
4435
09-28-2007 20:36:36
 How much more boost could a schwitzer produce in reply to dboll, 09-28-2007 05:05:46
My Air research does about 16 lbs max would a 3lm466 increase that. Tom
caseman,2
09-28-2007 03:48:34
Could be running short on air. check breather, and if it has a turbo take a look at it. good luck
