311B Oil Pan Removal
Henry Gardner
01-06-2000 17:59:51
I am trying to remove the oil pan from the subject tractor in order to rebuild the motor. I have discovered that there are 3 bolts in the back of the pan that are up inside of the flywheel housing. They are just far enough out of reach. I have removed the 2 bolts that hold the rear swivel bracket for the axle supports but it will not drop. If I loosen the clamp bolts on both sides of the axle, will the rear bracket drop enough for me to get to these 3 oil pan bolts? It does not appear so. Am I going to have to split the case up front and slide the front of the tractor away from the block in order to get at these bolts? I hope not! This is my first ever attempt at such a job and have not got all of the heavy equipment required to perform this type of surgery.
Any help would be greatly appreciated. Please also respond by email if possible...Thanks.
