Magneto-101
SDLoy
10-21-2007 10:23:53
I have a new to me CC, and the magneto doesn't snap. I haven't heard it run yet, but the previous owner assures me that it does run, just will need to be pulled to make it happen. Anyway, can someone refer me to a good site on resources for parts and repair? It is a base mounted mag, looks very similar to the one on my LA. thanks Loy
Walt Davies
10-21-2007 14:15:37
 Re: Magneto-101 in reply to SDLoy, 10-21-2007 10:23:53
this site has the complete manual on it for your use to download or just read.
Walt
sdloy
10-21-2007 15:46:15
 Re: Magneto-101 in reply to Walt Davies, 10-21-2007 14:15:37
Walt thats a great link, and I think the mag that's on my LA. Upon closer inspection the CC has an American Bosch MJAIB-112 magneto. thanks Loy
Walt Davies
10-22-2007 09:35:09
 Re: Magneto-101 in reply to sdloy, 10-21-2007 15:46:15
I had the manual and another friend had the software to upload it so we collaborated and put it up for all to use. the manuals are rare and hard to find.
Hope this helps all of you who need to work on your mag.
I have a neat way to time the mag on your LA I will post it later.
Walt
El Toro
10-21-2007 16:10:28
If you need to pull the mag make sure you make a note where the rotor is pointing before you pull it. Then don't move the engine while the mag is off the engine. When reinstalling the mag rotate the rotor to the same position you noted and install on engine. Hal
