1931 Case C Fan Belt
JoelV
10-22-2007 06:30:07
I recently aquired a C and while tore down for a radiator repair I decided to replace the fan belt. I see no adjustment to loosen up the belt to remove it. It is the "V" style, not the flat belt. How do these work? Help?!
Walt Davies
10-22-2007 09:43:33
 Re: 1931 Case C Fan Belt in reply to JoelV, 10-22-2007 06:30:07
I may be corrected on this but doesn't the pulley on the water pump adjust to take up the slack.
Walt
JoelV
10-22-2007 10:41:16
 Re: 1931 Case C Fan Belt in reply to Walt Davies, 10-22-2007 09:43:33
If that is the case, the pulley must have some sort of fastening method on the back side to let it travel up and down?
Thanks Walt....
DKase
10-22-2007 10:49:39
 Re: 1931 Case C Fan Belt in reply to JoelV, 10-22-2007 10:41:16
If it is the original CC water pump pulley it is cast iron, and the rear half is threaded so it will narrow up the pulley making the belt run higher in the pulley making it tighter. If it is a DC pulley it will be tin, and 2 or 3 bolts in the radius come loose and it turns in slots to tighten. DK
JoelV
10-22-2007 11:55:08
 Re: 1931 Case C Fan Belt in reply to DKase, 10-22-2007 10:49:39
Thanks for the reply's gentlemen....I'll check it a little closer this evening and see what I've got!
Joel
