1957 600 diesel
Old 600
10-23-2007 21:27:31
Wiring is shot.
Parts book looks like each wire has to be ordered separately and most of them marked retired. Does anyone know where I can buy a complete wiring harness for all the guages and lights. Don't need battery cables, but everything else.
JGarner
10-26-2007 16:57:53
 Re: 1957 600 diesel in reply to Old 600, 10-23-2007 21:27:31
I just got through building a new harness for my 630. Fabric loom cover material came from NAPA. They have 2-3 sizes. I usd 3/16" and 5/8". Hard to find several different primary wire colors locally, even in Houston, to match Case original color code so I went on line and finally found a site that would sell small lengths (25-35 feet depending on gauge). The company is Del City and they had all of the colors and gauges I needed but the red wire with black stripe. I used brown for that one since I had to buy 1000 ft minimum from the company that would put a stripe on the wire for you.
Later I discovered that big computer supply stores (not the Frys or Best Buy kind) those that sell wiring tools, connectors, resistors electronic plugs, etc. These guys sell a two wire set that is black and red, by the foot in several gauges. If you slpit them to individual wires it leaves your red one with a black stripe and you can always use 15-20 feet of black wire for various projects. Already had my loom stuffed and didn't want to redo the whole thing so I stayed with brown.
Sorry about the long post.
caseman-d
10-24-2007 20:20:02
I used to buy a fabric loom to run wires into to give them the original look. Haven't rewired any for a few years. Napa sold it buy the foot. For more than one wire run a stiff piece of wire threw first then pull the rest threw. On a 600 there can't be many wires.
caseman-d
bradley martin
10-24-2007 16:26:57
Why not build your own harness? It is not that complicated on the older tractors.
C. Amick
10-24-2007 09:26:19
Try calling John Brillman (Brillman.com). He doesn't list it on his web site, but that doesn't mean he can't make it.
