2390 lights
Jake1234
10-25-2007 19:56:02
I have a 2390 working just fine 1-2 months ago, then yesterday I went to use it and the lights hood lights stay on all the time. The lights stay on with the light switch off, key switch off and all the fuses pulled out, any commen problems or any ideas?
corey c
10-26-2007 14:16:37
 Re: 2390 lights in reply to Jake1234, 10-25-2007 19:56:02
front engine harness has rubbed and you have bare wires. The harness runs along the right hand side (oil filter side). Runs down along the starter then up to near the bottom right hand side of the radiator to a plastic connector. Check the harness carefully and you will find your problem. The 90 series had issues with the harness. Guys would park the tractor at night and in the morning the tractors might be started due to the short in the harness. Just an idea.
Jake1234
10-26-2007 15:00:18
 Re: 2390 lights in reply to corey c, 10-26-2007 14:16:37
just found the short, under the cab/back of engine, thanks for the help,
Also having a bear of a time removing the bulk head connection, any sugestions before i destroy it?
Eagle Doc
10-26-2007 20:27:40
 Re: 2390 lights in reply to Jake1234, 10-26-2007 15:00:18
Have you loosened the screw that holds the bulk head connector together? The head of the screw is on the bottom, in the middle of the connector. It might take a 5/16" or 3/8" socket - I don"t remember for sure.
Jim B
10-25-2007 21:15:42
Sounds like a defective switch. Does it feel normal, or is it too-hard or too-easy to turn?
There are no fuses for the lights. If the 2390 is like the 70 series older Case's then there is a circuit breaker on the switch itself.
Power to the lights does not pass thru the key-switch (ignition switch)... just like a car or truck. The lights may be required when the key is off/removed. This is, by the way, a law in some states.
Jake1234
10-26-2007 10:12:17
 Re: 2390 lights in reply to Jim B, 10-25-2007 21:15:42
I checked the ohms through the switch in all positions and the switch seems to operating correctly. Also when the switch is unplugged there believe that there is still power going to the hood/head lights 4 out of 6 leads.
