1937 CC Case
DGK CC Case
11-26-2007 16:09:03
Any one know the seal number for the input shaft to the transmisson.the one I have hase no numbers on it. Thanks David
larryneohiocase
11-27-2007 15:44:23
 Re: 1937 CC Case in reply to DGK CC Case, 11-26-2007 16:09:03
Sorry the only casting number that this book shows for a CC is the cylinder head and that shows that they are a 4570A. For whatevergood that does ya.
Sorry I couldn"t help.
Larry
larryNeohiocase
11-27-2007 09:36:13
Kirk,
I have a guide at home for casting numbers I'll take a look this evening and see if I have any information to help you out.
Larry
Nebraska Kirk
11-26-2007 20:09:54
Measure the diameter of the hole where the seal goes and measure the diameter of the shaft that goes through the seal, this will give you the outer diameter and inner diameter of the seal. Any good parts store can find you a seal with these two measurements.
