188G Combine Engine question
Jerry W
11-29-2007 19:32:28
I recently bought a case 188 gas power plant engine at a dealer liquidation auction and have a question about the hydraulic pump. The pump is gear driven out of the mag hole and the 2 primary lines (feed & pressure) exit out the back. Out of the right side of the pump thru what looks like a built in spool valve are 2 smaller lines. My question - is this a priority setup for power steering and if not what is it for?
jerry
BarryfromIA
11-30-2007 16:23:22
 Re: 188G Combine Engine question in reply to 4 R's, 11-29-2007 19:32:28
The first or smallest pump next to the block is the power steering pump. The next pump is the hydraulic pump for the system that would have raised the head. The small pump might only be useful on another hydrostatic type steering system.
