2 stick shifter
Roger Roemen
11-30-2007 15:19:51
What all is required to put a 2 stick shifter from an 830 non COM on an 800 COM? I just want to add that you guys have been HUGE help on my 800 project. Thanks
comfortking
11-30-2007 20:27:11
 Re: 2 stick shifter in reply to Roger Roemen, 11-30-2007 15:19:51
Shifter will fit. Just lift the steering post alittle and remove the shifter levers by removing the 3 nuts that hold them. Next remove top cover and then the shfter assembly. It does not matter if a com or dual range as shifter is in the four speed high low range compartment and all the parts are the same.
