1070 jerky clutch HELP
1070
12-19-2007 12:48:42
My 1070 powershift has a very jerky clutch. Is there anyway to help this?
Jim B
12-23-2007 09:46:03
 Re: 1070 jerky clutch HELP in reply to 1070, 12-19-2007 12:48:42
The PowerShift (RPS) tranny on all 70 series Case machines use an "Inching" pedal not a "Clutch" pedal to engage engine with wheels. The inching pedal is mechanically linked to a hydraulic control valve that controls the engagement of whichever multi-disc hydraulic clutches are used for the selected gear. Two clutches must be engaged for any gear.
The inching pedal has dissimilar "Feel" as compared to a manual friction clutch pedal! The release modulation needs to be slower if you what to minimize a "Jerky" action. Suggest you use less throttle during engagement, compared to a standard friction clutch, then throttle after the inching pedal is fully released. Kinda something an operator must learn for most any Powershift tranny.
