1951 VAC Case
w yeager
01-01-2008 17:46:09
recently bought a 1951 Case VAC model and was wondering what type of fluid to use for the hydralics and where do I put it in. Also it's missing a rear wheel weight and wonder if anyone knows where I can find one and also front end weights. The guy I bought it from has moved and can't contact him. Didn't notice the weight was missing cause he had replaced the one tire.
mj
01-02-2008 18:47:03
 Re: 1951 VAC Case in reply to w yeager, 01-01-2008 17:46:09
Here ya go-
Bunkumben
01-02-2008 09:34:07
I have VAC front and rear weights available, email if interested.
Ben
Mike Burton
01-02-2008 07:09:12
I've used hy-tran or an equilevent from the Case dealer or a place like TSC. There's a plug on the left side(I think) of the torque tube where you fill it. Rear wheel weights aren't too hard to find, someone on this site might be able to fix you up. Front weights seem to be tougher to come up with. Hope this helps, M.B.
