1952 Case DC 4 Tractor Hand Clutch Engage Problem
Dale Rainwater
01-05-2008 06:57:02
My 1952 Case DC 4 tractor's hand clutch lever will not move forward far enough to snap into place to engage the clutch as normal. When I hold the handle forward the clutch engages. However, as soon as I let go of the hand lever the clutch disengages. It appears the clutch lever travels half of the normal distance then stops before it snaps into place. Any assistance to diagnosis my clutch issue would be greatly appreciated. Thank you, Dale
L.Lamp
01-06-2008 19:01:54
 Re: 1952 Case DC 4 Tractor Hand Clutch Engage Problem in reply to Dale Rainwater, 01-05-2008 06:57:02
You may have a broken pressure plate where the three hinges that make up the over center part are fastened. This would explain why holding the clutch in makes it go. If a pin came out or an ear breaks off in there your overcenter pressure will be gone. Take a look in there and if nothing is broke, adjust up the clutch per manual instructions. Good luck.
Dale Rainwater
01-16-2008 06:39:56
 Re: 1952 Case DC 4 Tractor Hand Clutch Engage Problem in reply to L.Lamp, 01-06-2008 19:01:54
Hi L.Lamp, I loosened the clutch by 4 adjusting holes and it works as normal. Thank you for your response, Dale Rainwater
Gene Dotson
01-05-2008 10:52:44
Dale;
Are you sure you are pushing hard enough to get the over center linkage to snap in? A properly adjusted clutch requires 40 pounds of push to snap over center. A tighter adjustment may require a harder push... Gene
Dale Rainwater
01-16-2008 06:39:12
 Re: 1952 Case DC 4 Tractor Hand Clutch Engage Problem in reply to Gene Dotson, 01-05-2008 10:52:44
Hi Gene, I loosened the clutch by 4 adjusting holes and it works as normal. Thank you for your response, Dale Rainwater
Jim Mitteer
01-05-2008 10:51:05
Someone has adjusted the clutch too tight. You need to take the cover off the side of the clutch housing and back off the collar a couple of notches. Your DC owners manual shows the procedure.
Dale Rainwater
01-16-2008 06:37:35
 Re: 1952 Case DC 4 Tractor Hand Clutch Engage Problem in reply to Jim Mitteer, 01-05-2008 10:51:05
Hi Jim, The clutch was in fact too tight. I loosened the clutch 4 adjusting holes and it works as normal by snapping into place. Thank you, Dale Rainwater
