case air cooled 4cyl
vac 54
01-07-2008 17:34:05
couple Questions. valves. in take /exhaust .14 cold ? need to take top end apart.( head and barrels). where do i find gaskets ?? and tsx 581 carb gasket kit ????? any info please .
greygoat
01-12-2008 09:49:13
 Re: case air cooled 4cyl in reply to vac 54, 01-07-2008 17:34:05
Thanks, Jon, I learn something new everyday
greygoat
01-11-2008 13:25:56
I never heard of a Case 4 cyl. air cooled eng.
though I learn something new everyday. Are you
sure that it isn"t a "Wisconsin Air Cooled" ?
Case being in Racine, and Wisconsin being in
Milwaukee, makes me think that there could be
a connection. The most common auxillary engine
on bailers, of many brands was Wisconsin.
Any other clues, or markings? Does it have cast iron Jugs, in pairs, and aluminum heads ?
Magneto or distributor? What are the numbers
on those? I have a Wisconsin master parts manual
and collect Wisconsin engines. may be able
to help.
greygoat
01-09-2008 12:51:01
What kind of equipment or machine are you
refering to? Whose make of engine
vac54
01-09-2008 18:29:24
 Re: case air cooled 4cyl in reply to greygoat, 01-09-2008 12:51:01
this is a case air cooled engine off of a baler im trying to rebuild need gasket set, carb gasket, and specs. on tune up.
Jon Hagen
01-11-2008 13:43:39
 Re: case air cooled 4cyl in reply to vac54, 01-09-2008 18:29:24
Yes Case made an inline air cooled engine used on balers and small pull type combines.
They look a bit like a Duetz air cooled engine. An engine shop once told me that it was basically a VAC engine converted to air cooling.
I once repowered a cockshutt 30 with one of those engines, a little low on power for big jobs,but fun to play with and get a double take from people when they heard the jet engine like whine of the axial cooling fan and saw that the tractor had no radiator. :-)
I have no idea if any gaskets and such are still avalible. This was most definatly a Case engine, not a Wisconsin.
