Replaceing the rear axle seals on CC
Farmallb
01-10-2008 17:58:22
What is there to doing it?
Farmallb
01-11-2008 18:08:54
 Re: Replaceing the rear axle seals on CC in reply to balatonman, 01-10-2008 17:58:22
Well, Im 60, and im not a machanic, so I guess ill pass
J heitkemper
01-12-2008 15:52:36
 Re: Replaceing the rear axle seals on CC in reply to Farmallb, 01-11-2008 18:08:54
Try a qt or 2 of LUCAS hub Sealer .. Worked for me ,, NAPA carries it here in s. indiana
Jim Evans
01-11-2008 17:36:37
 Re: Replaceing the rear axle seals on CC in reply to Farmallb, 01-10-2008 17:58:22
Remove the transmission cover/steering box. Remove the PTO cover. Remove the wheels. Remove the chains. Remove the sprockets from the axles. Remove the axle housings. Remove the axles from the housings. Measure the seal and replace with 1 or 2 lip seals from Napa. Replace the axle bearings because they look bad. Rework every axle stud so you can get the nuts properly tightened. You can't get new axle gaskets. I clean it up and use Loctite 515 Anerobic sealant. Put it all back together in reverse order.
Piece of cake.
