1210 case powershift adjustment
David L Workman
01-12-2008 10:01:11
The tractor starts to move then stops. Moves about 3ft like its losing pressure.
Is there an adjustment or what can i check to see
what the problem is.
Thanks, David Workman
mEl
01-12-2008 13:24:59
 Re: 1210 case powershift adjustment in reply to David L Workman, 01-12-2008 10:01:11
Unless there are serious problems with the DB powershift mechanically it should default to low range even if it loses system pressure completely. I have had several that people brought to the shop that had bad main clutches that the customer thought was a powershift problem. There are others on here that may have more input to help you diagnose.
