Case Model 211B
chriscase211b
01-13-2008 13:03:23
I am rebuilding a 1958 211B and having problems. The lower gears don't work. When I have it in low gear it clicks. How do I figure whats wrong?
Chris
TimBinWV
01-14-2008 16:19:09
 Re: Case Model 211B in reply to chriscase211b, 01-13-2008 13:03:23
Chris,I may be able to help you out with gears,as I know a guy with a triplerange rear tractor half that should be good....email is open....
mEl
01-13-2008 13:17:04
Chris, do you mean the 4 speed shift or the range shift, in either case the top covers are very easy to lift off and inspect the gears and check the bearings. just be sure to align the forks with the gear slots when reinstalling, good luck. mEl
chriscase211b
01-14-2008 08:31:47
 Re: Case Model 211B in reply to mEl, 01-13-2008 13:17:04
Thanks ME1 i will pop the cover see what it looks like.
