12 Volt or 6 Volt?
LarryNeohiocase
01-23-2008 10:05:25
Should I assume that since my 1953 DC has a coil and not a mag that it has been converted to a 12 volt system? It still has a generator on it not an alternator. I thought that 6 volt coils were fairly avaiable. Thanks for the help.
Paul f
01-23-2008 10:39:29
 Re: 12 Volt or 6 Volt? in reply to LarryNeohiocase, 01-23-2008 10:05:25
No you shouldn't...Mine has a Delco Distributor and coil and is 6 volts.
LarryNeohiocase
01-23-2008 10:41:11
 Re: 12 Volt or 6 Volt? in reply to Paul f, 01-23-2008 10:39:29
Thanks for the input Paul. I just knew it couldn't be that easy.
Walt Davies
01-23-2008 10:23:23
99.9% of all coils are 6 to 8 volt and require a balance resistor when used with a 12 volt system. Just because you have a coil don't assume it has been converted to 12 volt. Check all the light and se if there is a resistor between the ign. switch and the coil if not then its most likely a 6 volt system also the generator will say 12 volts on the tag in most cases. Walt
LarryNeohiocase
01-23-2008 10:40:02
 Re: 12 Volt or 6 Volt? in reply to Walt Davies, 01-23-2008 10:23:23
Walt,
Thanks for the info. I'm gonna have to look at the generator tag if it's still there or check for the resistor because this one didn't have any lights at all when I got it.
Thanks again,
Larry
CWH
01-23-2008 15:44:46
 Re: 12 Volt or 6 Volt? in reply to LarryNeohiocase, 01-23-2008 10:40:02
Wouldn't checking the battery be the simpleist way to find out?
LarryNeohiocase
01-24-2008 05:35:36
 Re: 12 Volt or 6 Volt? in reply to CWH, 01-23-2008 15:44:46
LMAO!!!
Yeah CWH you have a point! When I picked it up the guy started it with a 12 volt and we loaded it. When I got it home I did the same thing to unload and move it into the garage. It currently does not have a battery in it.
Thanks
Paul f
01-24-2008 05:48:57
 Re: 12 Volt or 6 Volt? in reply to LarryNeohiocase, 01-24-2008 05:35:36
12 volts will not necessarily instantly fry a 6 volt coil. The starter motor won't care...so just starting it and running for a a couple of minutes may not be a sure indicator of voltage.
LarryNeohiocase
01-24-2008 05:51:05
 Re: 12 Volt or 6 Volt? in reply to Paul f, 01-24-2008 05:48:57
Paul,
Yeah I knew that I could get away with starting it off of that battery and moving it into he garage.
Thanks.
