800 diesel engine needed
j heitkemper
02-02-2008 21:10:01
May need a motor for the 800, found antifreeze where it should not be ,,
JGarner
02-05-2008 05:56:06
 Re: 800 diesel engine needed in reply to j heitkemper, 02-02-2008 21:10:01
These leaks are heck aren't they Jim. (<:
JGarner
Hoss in Maine
02-04-2008 17:26:09
Jim,8 o-rings.2 per cyl liner. Hoss
caseman-d
02-04-2008 04:38:18
 Re: 800 diesel engine needed in reply to Rodney Dykstra, 02-02-2008 21:10:01
Could also be a head gasket leaking. One of the easiest ways might be to pull the oil man and see if you can tell where it's comming from. I have a 800 that I overhauled and after about a year it started to get antlfreeze in the oil. Thought that maybe it was the orings but I seem to have it on top of the pistons. I only use mine in the summer so I just run straight water and then drain it when done. Tractor runs so smoothly one would never know there is a problem.
caeman-d
Jim From Calif
02-03-2008 08:49:48
A likely cause for anti-freeze in the crankcase can be a sleeve o-ring leaking. This allows anti-freeze into the crankcase oil. Not a hard problem to fix, however, you should replace all four o-rings when you have it down.
