1953 Case VAC 14 hand throttle
BI
02-15-2008 13:53:07
I am trying to find an original hand throttle for my 1953 Case VAC 14. I am pretty sure it is NOT the one that mounts on the steering column I believe that is on the earlier VA models, I believe the one I need mounts on the dash. Currently mine has a pull and twist to lock throttle cable and I want to replace it. I"m not sure what an original even looks like. I think the linkage under the gas tank is fine because I can use the foot throttle fine and it is linked with the hand throttle cable. If someone knows what I need or has a picture or can help I would really appreciate it. Thanks in advance.
mj
02-15-2008 17:44:04
 Re: 1953 Case VAC 14 hand throttle in reply to massey333, 02-15-2008 13:53:07
BI said: (quoted from post at 15:53:07 02/15/08) I am trying to find an original hand throttle for my 1953 Case VAC 14. I am pretty sure it is NOT the one that mounts on the steering column I believe that is on the earlier VA models, I believe the one I need mounts on the dash. Currently mine has a pull and twist to lock throttle cable and I want to replace it. I"m not sure what an original even looks like. I think the linkage under the gas tank is fine because I can use the foot throttle fine and it is linked with the hand throttle cable. If someone knows what I need or has a picture or can help I would really appreciate it. Thanks in advance.
Click this Link and go to Image #26 .... you click the image to enlarge. Image #27 has the part numbers and descriptions.
Also, I've got a tractor here that I can take photos of if you need that.
third party image
