1070 power shift shifting problems
martin in DE
02-24-2008 13:21:41
havin problems shifting out of reverse the transmission shifts real hard. Any idea what the problem may be?
mEl
02-24-2008 17:09:06
 Re: 1070 power shift shifting problems in reply to martin in DE, 02-24-2008 13:21:41
Does the power shift lever move hard when the engine is shut off from r through 3rd power shift, if so the cable is tight , replace it, don't try to lube or fool with it. The 4 speed is a separate part of the transmission from the powershift, does that shift hard also. give more specific info, we will try to help
