2590 needs a bit more hp
foothill
02-24-2008 17:24:48
hi, pulling a liquid spreader with a CASE 2590 over the road. I have one hill that I cannot pull unless I shift ranges which in turns spills a little liquid on the road and the neighbors get really mad. how do I turn the pump up a little to get a bit more power? right now the tractor does not smoke at all. thanks, ray
billy bob
02-26-2008 04:46:05
 Re: 2590 needs a bit more hp in reply to foothill, 02-24-2008 17:24:48
I know it may take longer but you may want to change gears before you start up the hill. It can not be good starting out under that heavy load on a hillside.
Doug Boll
02-25-2008 13:26:44
install a Sweitzer 3lm466 turbo, they are reasonably priced, durable, bolt on and make more psi of boost than the A R to4
D-C-741
02-25-2008 10:31:19
My Brother has a 2390 Turns about 235 HP,It aint Hurt it yet !You need to Turn the Fuel Screw a Bit.It's under ther cover with the 4 bolts on the lower back,Its the one with the Screw head,try 1/2 a turn in at a time till you think its ok !Call me if you need more information. 607-564-7536 Dale
foothill
02-25-2008 06:57:20
the spreader holds 3750 gallons and it is one heck of a hill that I have to completly stop and shift to range 3. I read the previous posts i will give it a try , thanks, ray
JoeBob/IN
02-25-2008 10:14:28
 Re: 2590 needs a bit more hp in reply to foothill, 02-25-2008 06:57:20
I suggest a pyro! You can melt the pistons in a hurry when you give them more fuel.
JoeBob/IN
02-24-2008 18:07:09
Do you mean you have to powershift or actually change gear range? Must be one heck of a hill for a 180 horse tractor to not be able to pull or one heck of a load, or both! I actually just posted a question the other day about the fuel screw on the Bosch fuel pump. Look back a page or two and it is there!
