Had Another One Follow Me Home.
caseman-d
03-09-2008 19:40:56
Went to check out a DC-4 that my brother knew about. Really wasn't interested in buying another one. What did intrest me about this one was it was a DC-4 with eagle hitch. I already have one with stuck motor and needing lots of TLC. This one was parked in a shed over 10 years ago because the pto was slipping. Was a bit disipointed in it when I first seen it.
third party image
All four tires were flat, rears had cracks in them, fronts looked fair.
third party image
Turned out the engine still turned over, gas tank was clean, no old gas, radiator smelled like it still had anti-freeze in it. No fenders, piece missing off eagle hitch, but good sheet metal as you can see. He asked me to make an offer so I made a low offer, he wanted more. His asking price was still low so I accepted his price.
Went to get the tractor today, he had a service truck so we could air the tires. I was surprised how well the tire blew up. Got the tractor out side for the first tme in over 10 years. I brought a battery and some gas hoping it would start. I turned the engine over with the starter slowly to make sure no stuck valves. We tried but couldn't get it to fire so we pulled it on to the trailer. Found out it has good brakes.
Well it followed me all the way home. Even in the wind :P .
third party image
third party image
Once home I pulled the dist. cap off, no leaf bugs. Took some emery cloth and sanded the points. Put it back together, checked the oil for water and anti-freeze, no condensation or anti-freeze in the oil. Added 2 qts of oil, put battery back in, turned switch on and hit the starter button and it started right up. Shut it back off and undid the chains.
third party image
third party image
Once unchained and ramps out I fired it up and backed it off the trailer. Added a couple gls. coolant and took it for a small spin. Seems to have about 30 psi oil pressure idle or high rpm. Might need new heat gauge but showed no signs of gettig hot. Had good power when riding the brakes, eagle hitch slow so I'll have to pull it in checkit over before using it. Out of shed space so it will set out for first time in over 10 years. Battery was dated 94. Enjoy the pctures
third party image
caseman-d
Ande
03-10-2008 08:46:32
 Re: Had Another One Follow Me Home. in reply to caseman-d, 03-09-2008 19:40:56
I dont know what you paid,and it doesn"t matter,you got a nice tractor,you can put to work again.
caseman-d
03-10-2008 11:35:35
 Re: Had Another One Follow Me Home. in reply to Ande, 03-10-2008 08:46:32
With gas and dinner I was still under 600.00. Not counting my time or wear and tear on my rig.
caseman-d
triplerange
03-10-2008 17:42:53
 Re: Had Another One Follow Me Home. in reply to caseman-d, 03-10-2008 11:35:35
Nice find. I did enjoy the pics. Hope you can find a use for 'er. You shouldn't have told us what you gave...coulda doubled your money easy!
caseman-d
03-10-2008 18:25:29
 Re: Had Another One Follow Me Home. in reply to triplerange, 03-10-2008 17:42:53
Yes I probably could have doubled my money, this one makes up for some of the not such a good bargin. I got to take it to a pull or 2 and see how it does. Always nice to have an extra eagle hitch tractor.
caseman-d
Ande
03-10-2008 16:48:07
Case,you did good.That was a buy.Fun to win sometimes.Especially the good guys
R Aiken
03-10-2008 07:27:12
Looks good, I had 2 more follow me home last week. A DC for parts and a good VAC14.
Paul f
03-10-2008 04:57:53
Nice tractor....What part of the eagle hitch was missing??...I didn't catch it in the pictures
Too bad about having to be outside...I could give it space in my shop :-)
caseman-d
03-10-2008 19:15:04
 Re: Had Another One Follow Me Home. in reply to Paul f, 03-10-2008 04:57:53
Paul,
Mostly small stuff, plug on top of lift arm that caused it to freeze up, part of crank handle missing. Would of been nice to have third link, the steps for the lift arms. Just the normal stuff that seems to be missing.
JGarner
03-10-2008 08:31:41
I would bet caseman-d is referring to the cast PTO cover which is where the top link mounts for a low mount. Looks like the high mount point is still there, either that or the top link itself. All of which can be purchased as reproductions from John Saeli.
