164 wet sleeves
comfortking
03-18-2008 20:28:57
I am in need of sleeves for a 164 wet engine. Case no longer handles them, I can get them made but they need to run 250 of them. Is anyone else needing this sleeve set?
martin in DE
03-19-2008 17:37:34
 Re: 164 wet sleeves in reply to comfortking, 03-18-2008 20:28:57
what is the difference in the G159 sleeves.
Greg Breisch
03-19-2008 07:37:07
The sleeves are still avalible throu Case. I have the part number if you need it
Jim McVay
03-18-2008 21:19:48
What are you going to use those sleeves in? What pistons will you use with them?
comfortking
03-19-2008 02:57:41
 Re: 164 wet sleeves in reply to Jim McVay, 03-18-2008 21:19:48
Sleeves go in a 511b. I could have pistons and rings made also. G 159 sleeves work on top but not on bottom.
Jim McVay
03-20-2008 18:49:28
 Re: 164 wet sleeves in reply to comfortking, 03-19-2008 02:57:41
The 2 164 engines I have been into both had dry sleeves.
Alan Golden
03-18-2008 20:40:06
Check with Tom Underwood in KS. He might have what you are looking for. 785-749-5231
