1594 Fuel Filter Replacement
RD TX
03-20-2008 08:06:10
If I replace the fuel filters on my 1594 do I have to bleed the air out of the fuel lines to start the engine.
KevinT
03-20-2008 10:19:12
 Re: 1594 Fuel Filter Replacement in reply to RD TX, 03-20-2008 08:06:10
I am asumming that this is a diesel and therefore yes. You probably have 2 fuel filter, Primary and secondary and on to of each shold be a bleeder screw. On the tank side of the filters in the fuel line there should be a tee with a hand pump for this process. Depending on how much stuff in the in the way it sometime is not visible. On top is a disc that unscrews and pops out. Pushing it up and down will prime the new filters. Open the bleeders primary and then secondary and pump until you don"t see any more bubbles.
