188 Diesel Block
cnj152
03-23-2008 14:22:19
Thanks in advance.
I would like to hear from someone who has exprience with a block that is cracked in the bottom. The cracks do not go to the main bearing webbing. I had experince with the 148 being cracked in the top no problems ever came from those cracks.
cnj152
03-26-2008 17:26:24
 Re: 188 Diesel Block in reply to cnj152, 03-23-2008 14:22:19
The cracks are between cylinders in the lower end of the block.
C. Amick
03-26-2008 16:23:22
Is it an external crack at the bottom or is it internal between cylinders? Is it seeping coolant? Was the block frozen or is it some sort of stress crack? Case S Series tractor blocks are know to crack near the bottom behind the carburetor. It's not a problem in this instance because the coolant leaks to the outside of the block and is easy to repair.
