1937 c magneto
lee nordvold
03-23-2008 17:06:02
What is the firing order,location of timing marks,and any info on a american bosch model #
mja4b112 magneto thanks
El Toro
03-23-2008 18:16:36
 Re: 1937 c magneto in reply to lee nordvold, 03-23-2008 17:06:02
You need to bring No1 piston near the radiator to TDC on the compression stroke and then look to see where your rotor is pointing and that should be pointing to the No1 plug wire on the cap. Note which way the rotor is turning then your plug wires need to be in this firing order 1-2-4-3. Hal
Tom Railsback
03-23-2008 18:22:32
 Re: 1937 c magneto in reply to El Toro, 03-23-2008 18:16:36
That's not right; the firing order is 1-3-4-2. It should sat so right on the side of the block.
El Toro
03-24-2008 03:41:10
 Re: 1937 c magneto in reply to Tom Railsback, 03-23-2008 18:22:32
That is right thanks for correction. Hal
