2094 Powershift problem
Triplerange
04-03-2008 09:51:31
Hey, I have a 2094 that wants to start out in medium range. After about 2 seconds of letting out of the clutch pedal it drops back to low. I've replaced the cable to the cylinder, which was froze up, but the shift problem is still there. The cable to the shift solinoids looks ok. Could one of those contact switches under the pedal be the problem or is it something else?
turbo
04-03-2008 10:36:05
 Re: 2094 Powershift problem in reply to Triplerange, 04-03-2008 09:51:31
Most likely the relay box is failing. It is at the front of the RH console and can be seen after you take off the lower cover. It has 11 wires connected to it. When there is a problem they go to medium or safe mode. $160 or close.
Triplerange
04-03-2008 11:09:17
 Re: 2094 Powershift problem in reply to turbo, 04-03-2008 10:36:05
Thanks Turbo...anyway to check it?
