1410 David Brown(Case)
Tony Mac
04-13-2008 20:50:21
I have a 1410DB(Case) the 3-point not working, the remotes work, I have taken the valve's out and cleaned them(2 screws on the right hand side of tractor above the axle). I took the plate cover off above the PTO and seen the fluid pumping out thru a small line, then I took the plate cover off behind the vale (on the right hand side of the tractor (back side of axle)and watched the housing fill up with fluid when I worked the 3-point lever, but the 3pt doesn't move. Any suggestion?
swood43@valornet.com
04-14-2008 12:46:38
 Re: 1410 David Brown(Case) in reply to Tony Mac, 04-13-2008 20:50:21
The hydraulic line from the control valve to the 3 point lift cylinder is a two piece line and runs under the ring gear. I worked for a case dealers shop in the eighties and we would pull the axles and ring gear out to tighten the line at the connection that was directly under the ring gear (brass fittings). We would use loctite or at the cutomer request once brazed the brass fittings together. Not sure if the 1410 you have is like that but I would bet it was.
richardinnz
04-14-2008 03:54:06
Is the dump valve (if fitted) in the correct position?, Is the 4 way selector valve in the correct position?
davebr
04-14-2008 01:20:20
Have you changed the filter on the bottom of the case? Clean it and fill with new fluid? Is the hyd fluid low?
Dave Brown
Tony Mac
04-15-2008 06:44:01
 Re: 1410 David Brown(Case) in reply to davebr, 04-14-2008 01:20:20
Thanks for all the suggestions, I have changed all fluids,filters, and cleaned all screens, I will check the fitting under the ring bearing this week end and let you all know, Thanks.
Tony Mac
04-24-2008 08:56:09
 Re: 1410 David Brown(Case) in reply to Tony Mac, 04-15-2008 06:44:01
I been using the tractor and havent been able to check for the leak, I hope to this week end, Thanks
Tony Mac
04-30-2008 05:19:31
 Re: 1410 David Brown(Case) in reply to Tony Mac, 04-24-2008 08:56:09
O.K. guys, I followed the lines under the ring gear, they all come from the left side, 1 coming in from the front and spliting, 1 to the pto gears, 1 to the right side and 1 to the left side all of them are secure with no leaks. I checked the lift line(external) and there is no fluid coming out. The line is coming in from under the remote valve, the pump is feeding the remote housing and this line splits off the housing and goes over to the left into a housing block that has a knob on top that pulls up and pushes down,(diverter?) but there is'nt any fluid coming out of the line. The fluid in the other places I checked seems to be strong and plenty. Any suggestions?
