Case DC4 magneto to coil
jim j wieringa
04-17-2008 09:57:33
Got a DC4 with a bad magneto. How does one go about switching it to a distributor and coil system? Or is it cheaper to buy a different magneto? Looking for options. jim
DCDENNIS
04-21-2008 18:34:27
 Re: Case DC4 magneto to coil in reply to jim j wieringa, 04-17-2008 09:57:33
third party image
Just thought I would show you what I did with my dead lai, got this idea from a good fellow in canada, cant rember his name, took a little machining, but now I know it is not the mag that was causing my missfiring, DCDENNIS
C. Amick
04-18-2008 09:09:26
The horizontal IH Farmall distributors from Cub through M will work, see link below. The vertical Delco units off such tractors as a WD Allis Chalmers will work a little better. Make sure the drive mechanism that fits onto the shaft is with it, see photos in link below. All you have to do is remove your magneto and bolt this unit on using the same bolt holes and mount an external coil.
Paul f
04-18-2008 06:21:51
Right angle distributor is easier to install. Look for a Delco-Remy Model 1111411.
Internal parts are available off the shelf at an auto parts store
Borg Warner Part # are:
Points A40V
Conden G102A
Rotor D10
Cap C150
El Toro
04-18-2008 04:28:51
third party image
Here's a picture on how to switch a mag to a distributor. You will need an auto type coil, ignition switch and battery voltage fed the coil.
Disconnect the mag's coil at the points and run a wire from the new coil to the points. You will need to remove the ground wire on the mag used for stopping the engine. Hal
C. Amick
04-17-2008 19:03:17
Did you try cleaning the points on the mag with find sand paper or emory board? That's usually the most common problem.
jim j wieringa
04-17-2008 17:36:00
Thanks for the opinions gentlmen..... ....jim
jal-SD
04-17-2008 13:36:13
We've had to convert several due to unavailibility of parts for the Case mags. The right-angle Delco's used on Allis & Farmalls work good-they bolt right on. I think the rotation is the opposite way, but just wire the plugs correctly. Parts are available @ your friendly I-H dealer or at NAPA. If you have an alternator, just get a 12V coil. (My $0.02 worth. jal-SD)
JGarner
04-17-2008 12:57:04
This is just my personal opinion others may feel differently. If you have a dead or no battery you can crank start the mag equipped tractor but with a distributor and coil its no dice. Didn't plow with it at night, but we never had a battery on our LA it was always started with the hand crank.
I would repair or replace the mag if it were mine as it would look more original. Most SCs and DCs you see with a dist/coil set up were aftermarket conversions.
