1955 case tractor LP
russell landret
04-18-2008 06:23:20
I have a 1955 case tractor would like to know how to find the model it is a LP-propane it has 18.4x30 rear tires only number i can find is on the motor block it has a pto and hydro on the rear there is a lot i want to know if i only knew the model number
Hoss in Me
04-18-2008 15:17:12
 Re: 1955 case tractor LP in reply to russell landreth, 04-18-2008 06:23:20
Ser. No is stamped on block flange whera eng.bolts to bellhousing on left hand side sitting on tractor. Hoss
russell landreth
04-19-2008 11:14:46
 Re: 1955 case tractor LP in reply to Hoss in Me, 04-18-2008 15:17:12
Hoss the only number i found is 523 stamped on the motor block left side when sitting on the tractor
DKase
04-18-2008 08:38:47
4 or 6 cyl. engine? How many speeds in the trans?
russell landreth
04-19-2008 04:45:14
 Re: 1955 case tractor LP in reply to DKase, 04-18-2008 08:38:47
4 cyl.4 speed from what i understand from the seller who i bought it from it is a 50 horse engine thats all i know thanks for answering
Doc Larry
04-19-2008 08:46:53
 Re: 1955 case tractor LP in reply to russell landreth, 04-19-2008 04:45:14
Based on the tire size and LP and age, probably a 400 (NOT a 400B). If so, it has 8 speeds forward 2 reverse, all in a single shift stick.
Larry
