1845c warning overtemp horn/light
markinwa
04-18-2008 09:25:00
when driving or loading my light/horn keeps going on and off coolant level fine and circulating nice sometimes comes on right at start up and stays on all day tried to trace with vom meter but likes to fix itself when sees me coming with meter
mEl
04-19-2008 04:31:40
 Re: 1845c warning overtemp horn/light in reply to markinwa, 04-18-2008 09:25:00
As a way of eliminating I would temporarily disconnect the water temp sender on top of the head by the radiator hose behind the lift bracket, we have had a signifigant enough amount of these go bad to start there. good luck, mEl
Dairy Farmer in WI
04-18-2008 18:21:51
did you check to make sure that the sensor wire is hooked up? also make sure the wires aren't shorted out or rubbed through anywhere. also have the sensor tested to make sure that that is still functioning like it should.
DF in WI
jstpa
04-18-2008 10:19:15
I'm not familiar at all with that tractor, but alot of times when multiple lights and such start coming on that are seemingly unrelated but started at the same time, it ends up being a bad ground, possibly to dash , or cab if so equipped , jstpa
