1950 case dc head gasket
tooltime
04-23-2008 19:47:54
is it hard to install a new head gaskeT ON A 1950 CASD DC Tractor? can i get a gasket from case IH Dealer? also, is a repair manual still available for such a tractor? Thanks,Jim
grapefarmer
04-25-2008 10:15:14
 Re: 1950 case dc head gasket in reply to tooltime, 04-23-2008 19:47:54
The only hard part is lifting the head off, its heavy. Have a friend help.
-Dave
Tom Railsback
04-23-2008 20:56:33
Installing a head gasket is not terribly complicated; it just takes a little time. As far as I know the gasket set is still available from CNH; the original part number was 4056AA which has probably been superseded, but should show up on the computer.
Service manuals show up on Ebay regularly.
tooltime
04-24-2008 05:05:56
 Re: 1950 case dc head gasket in reply to Tom Railsback, 04-23-2008 20:56:33
Thanks, i will try locate a new gasket set, ill let you know how the job goes. Jim
Tom Railsback
04-24-2008 07:35:48
 Re: 1950 case dc head gasket in reply to tooltime, 04-24-2008 05:05:56
There's a set on Ebay right now.
Tom Railsback
04-24-2008 09:03:03
 Re: 1950 case dc head gasket in reply to Tom Railsback, 04-24-2008 07:35:48
I just checked at the local CNH dealer. A valve grinding gasket kit consisting of the head gasket, valve cover gasket, 2 manifold gaskets and 2 water outlet gaskets is part #A189556 and sells for $85.85. The head gasket and valve cover gasket as individual items if purchased separately total $89.89.
tooltime
04-24-2008 10:13:51
 Re: 1950 case dc head gasket in reply to Tom Railsback, 04-24-2008 09:03:03
Tom, Thanks so much. It never fails, That Tractor lovers are the best. I appreciate your help, Jim
