1070 wheel spacing
ihr190
05-03-2008 17:57:00
I just got a 1070, it is currently set up for narrow rows. I have wide rows. I dont have an owners manual for it yet. Does anyone know how far to stretch the front and rear axles? Another question, I also need the line of draft to be as close as possible. I have 5-16 plow. Also, is this a simple task? It looks simple, but I dont know what decade the front axle was last moved.Thanks in advance. Rob
Dairy Farmer in WI
05-04-2008 20:01:06
 Re: 1070 wheel spacing in reply to ihr190, 05-03-2008 17:57:00
if i was you i would figure out how many rows the tractor will straddle ( prolly 2) then walk out to your planter and measure from the middle of one row spacing, go two rows over and measure to the middle of that row spacing. then set the wheels that far apart. but be sure to measure from the middle of the tires. as for the front axle. it should not be rusted too much if any. might come out hard but don't do any pounding on the spindle and just take your time. and remeber, when you move the fronts out, the tire should line up with the middle of the rear.
that's just the way i would do it
DF in WI
