1070 power shift Thanks
Dan M.
05-19-2008 19:27:35
Thanks garyga
do you have any tips on rebuild of C2 & C3 power shift
do you use the adaptor to lock the clutches with air when you install the output shaft??
any tips would be appreciated
Thamks
mEl
05-21-2008 08:24:09
 Re: 1070 power shift Thanks in reply to Dan M., 05-19-2008 19:27:35
Bison is right, they must be put together properly, new bolts and washers, timed properly to insure the oil passages are properly aligned and everything cleaned immaculately and primed and loctited and torqued while on a pilot shaft to insure that the shaft can be installed after torqueing. I have not used a air tool for many years, I put them together as if they were the later style, just spin the planetary and the plates engage theselves, When all are engaged the spacer, washer and snap ring will go into place letting you know all the plates are in place. If you are not an experienced mechanic you may want to have someone do this who has experience as if it is not done properly it will not stay together.
Bison
05-20-2008 22:21:20
get yourself a manual, these powershifts are complicated and without a manual you will be groping in the dark, there is a sequense how to put them together properly, and parts are stupedly expensive
