C-H
Don Ditmars
02-11-2000 19:27:36
Does anyone know how many "C-H" models were actually produced? Another one has just surfaced so I am sure the 7 is incorrect.
Bruce
02-14-2000 19:08:29
 Re: C-H in reply to Don Ditmars, 02-11-2000 19:27:36
The CH Case, as I understand it, there were 7 built originally. And they were stamped with a CH and another prefix. I am not sure what the other prefix was. The Case Co. brought several CC's back into the factory and made them into CH's and those were stamped just CH. They took the brakes and motor lifts off of them, they also changed the mags and took the row crop front end and put wide standard axles under them with British spindles. And with the British spindles, the spindle was on the bottom. Some of the tractors had a block in them between the axle and the radiator support and some did not. The axle fastened to the radiator support like the C's did. The one that I have according to the bill card was sent from the factory on rubber tires to North Dakota. When I bought the tractor it was on cut down steel, so I think the tractor was put back on steel before it was sold, most likely do to the buyers request. That is why there are more CH's then we think there should be.
Bruce
Billybob
02-12-2000 20:16:01
I have a CC-4 on rubber styled the same as the CH except mine has brakes .I believe if I had new tires axel and drawbar measurements would match.only missing by an inch and a half.
Chances R
02-12-2000 05:57:26
I dont have the answer, however your right, there are more than 7 in my opinion. My cc4 has a CH style front end on it.
